OneCraftyGal wrote:WOW Are you actually cutting the polymer clay with the cricut? Do you put it directly only the mat or use a paper between them? Does it clog the ctter blade? How thin do you roll it? How do you keep the clay from stretching out of shape when you move it from the mat? Sorry for all the questions but I'm really excited at the posibilities this might open up.
I don't use the Cricut but the Gazelle. Since the Cricut will cut gum paste it will probably cut clay. The only problem I can see with the Cricut is having the blade drag over the design while cutting. With the Gaz you have to option of using an O-ring which lifts the blade up when traveling and then the blade is lowered to cut (have to change the force setting so it will go deeper to cut). I also flip the design so it cuts on the wrong side since marks from the cutter are hidden from view.
I use a clay machine to roll the clay thru to make it thin evenly. The clay machine, which is a glorified pasta machine, will roll clay paper thin. The machine has different setting. If you use the paper thin setting, you might have a problem removing it from the mat. My mat wasn't overly sticky and clay will stick to the mat a little itself. If I need a piece larger than the machine will make which is only about 4 in wide, I knead the two pieces together until the seam if invisible and then cut. When putting two pieces together, only work at the seam so you will know just how thin to make it (hope that was understood).
Once again, unfortunately, I use the Gaz so my bladeholder can be taken apart and cleaned...am not sure about the Cricut. If you check the web for tuts using the Cricut to cut gum paste before the cake came out, there will probably be instructions for cleaing the bladeholder.
HTH
Althea
