Help with SVG
Help with SVG
Every time I create my own SVG from an image and then pull it into SCAL, the cricut cuts it out twice and it looks terrible. I can't see any double lines in either Inkscape or SCAL. I've attached a simple svg I created for a grad card. Would some one be willing to take a quick look and let me know what I'm either doing or not doing? Thank you so much in advance.
- Grad hat card3.svg
- (26.13 KiB) Downloaded 204 times
Re: Help with SVG
You had the usual double lines from tracing.
Open it in Ink
Select your iimage
From the menu, Path/break apart
View in outline mode (View/Display mode/Outline)
Delete one line
Open it in Ink
Select your iimage
Delete one line
- (13.66 KiB) Downloaded 219 times
Re: Help with SVG
Thank you so much! I am going to try that with mine at home but in case it doesn't work I downloaded yours.
Re: Help with SVG
It cut double on mine too. I can see a second line. Heather's advice is correct.
