Cutting Template
Pate48
Cutting Template
Post by Pate48 »
Downloaded a envelope template. Did the inkscape thing and have a svg file to import into scal. When I cut in scal the little window stays on checking mat and the cricut is cuting over the same line many times. The outline in scal looks sort of thick. What did I do or not do whichever the case may be. Thanks in advance.
kat78
Re: Cutting Template
Post by kat78 »
...this sounds as if you have duplicates of one layer laying on the others!
This happens when you convert pictures into vectors!
open the svg again in inkscape/illustrator and delete duplicate lines/vectors!
good luck!
Soraya
Post by Soraya »
i also appreciate this question and the reply. I was having the same problem. :oops:
soraya
deliacm
Post by deliacm »
Can you post a link to the file you downloaded?
Christina
“I do that which I cannot do in order that I may learn how to do it.” ~Picasso
Without seeing the image that was traced or the svg, I would guess that you have a sketchy trace. You should either try the paint bucket tool, or increase the threshold when you are tracing to get solid lines. See this post on the paint bucket. http://forums.surecutsalot.com/viewtopi ... &sk=t&sd=a
If you choose to try tracing again, increase the threshold until you get solid lines on your trace. Sometimes I have to go all the way up to 0.9 or 0.95 depending on how light the original image was. You then need to break apart the image and delete the extra lines.
Pate48
Post by Pate48 »
Thanks all, got it working. Thanks again for the help.
