In version 2.038 and later
File/export
Select the file format as Inkscape or Illustrator (I prefer Inkscape)
Open in Inkscape
The file will be "grouped" ungroup (sometimes more than once, see info line on bottom of Inkscape window until there are no groups
That should do it.
Export to .svg
Export to .svg
Re: Export to .svg
I'm running the latest version 2.041. When I do a File - Export all the options showing are .svg, .bmp, or .png. I don't have a choice of "inkscape" or "Illustrator" versions of svg. What am I doing wrong? Because when I go to import into inkscape all that shows is a large white rectangle box.
Gregg
Gregg
Gregg
Re: Export to .svg
I am running 2.041 also and experienced the same thing last night. However, I decided to "select all" just to see what happened and the paths were there - I just had to change the color from white to something that would show up.
Re: Export to .svg
SVG is an inkscape file
Scrappin My Way Through
