Bear Kiss
Re: Bear Kiss
ok... I have this... and I wanted to seperate the red from the black so I can cut it and piece it together.... is this possible? I took it to inkscape and and tried path then break apart and it did nothing. Any help would be great!
- maine.svg
- (2.02 KiB) Downloaded 240 times
Re: Bear Kiss
I am new to this. How do I get this to work. When I save it, it saves as an explorer page and the scal can't read it. I can't seem to save it as a .svg all on it's own. Do I have to open it in another program in order to save it? HELP!
Jen
reelcrafts@comcast.net
Jen
Re: Bear Kiss
I love this it cuts fantastic. TFS. and all you talented ladies thanks for sharing and especially thanks for the monitary help this is like pennies from heaven hehe. That makes you all angels thanks so much
Re: Bear Kiss
Jen wrote:I am new to this. How do I get this to work. When I save it, it saves as an explorer page and the scal can't read it. I can't seem to save it as a .svg all on it's own. Do I have to open it in another program in order to save it? HELP!
Jen
click the "Bear Kiss.svg" link under the second picture.
if you want the pictures to go with the .svg file then right click the image and click "Save image as"
Re: Bear Kiss
I believe you are leaving out a lot of steps. I tried to replicate what you get and found that you are just doing a save as.scrappy_happy_moms wrote:ok... I have this... and I wanted to seperate the red from the black so I can cut it and piece it together.... is this possible? I took it to inkscape and and tried path then break apart and it did nothing. Any help would be great!
You have to select the bitmap (the original picture and will have arrows around)
Path>Trace Bitmap (I usually use the top option and modify (clicking on update will show change as you modify the setting)
Once you have the correct setting, click on OK
Path>Break Apart and move/color the shapes as necessary
Save file
Re: Bear Kiss
Anointed hands: Here is the file I thought it was a jpeg but its a gif file will that matter?
- maine.gif (44.75 KiB) Viewed 3478 times
Re: Bear Kiss
Maine .svg file attached. Let me know if you need any further adjustments.
- maine.svg
- (23.63 KiB) Downloaded 275 times
- Picture1.jpg (13.54 KiB) Viewed 3461 times
Re: Bear Kiss
Could the Kissing Bears and the Maine Lobster and any others in this thread be put into one of the categories above? That way people in the future might be able to find them easier than search all threads.
Re: Bear Kiss
Cool! This makes me want to go to Maine and get lobster just so I can us it!
Shirl
Shirl
