New updates for SCAL2.
Re: New updates for SCAL2.
When i import svg files they come in huge!!! Like 400 inches tall. Is there something i can do to fix this! I know how to fix it once it is on the mat but is there anything tha can be done to avoid it from happening?
- Location: Dartmouth, Nova Scotia Canada Using Scal2, Inkscape .47, Vista
Thanks this so awesome. I love it.
You can set the default source as Inkscape instead of Illustrator, and the files will import a little smaller. They import at the size they were made. The problem is that they aren't always made at a size for cutting. I know that before SCAL2 I rarely paid attention to the size I was working with since it didn't matter when importing into SCAL1.esheen wrote:When i import svg files they come in huge!!! Like 400 inches tall. Is there something i can do to fix this! I know how to fix it once it is on the mat but is there anything tha can be done to avoid it from happening?
Thank you for the suggestion - I changed it and when I imported an SVG file, it again came in at 545 inches tall! Whew. I was able to import normal sized SVGs before the update. Am I the only one having this problem?
Try opening the file in Inkscape to see what size it is there. I haven't had any problems with the update and XP or Vista. If it isn't the file I don't know what else to suggest.
I have opened saved svg files from myscrapchick.com and those files open HUGE! My svg files from other sites seem to open at a reasonable size. My own scut files that I have saved open up at the correct size but i can't delete them when they are on the mat. In order to get rid of my own scut files,I have to start a new project and wipe the mat clean. ?? I am using Windows 7.
I have SCAL version 2.004, that was the first that I purchased. How do I get the downloads for the updates?
Just go back to where you first downloaded and get the newest version and install it.nana_bugaboo wrote:I have SCAL version 2.004, that was the first that I purchased. How do I get the downloads for the updates?
No need for registration codes or anything (well if everything goes smoothly
Craigg64 wrote:Just go to here http://www.craftedge.com/download/download.html and download the right one for your computer, either version 2.006 for windows or 2.004 for Mac.momof6 wrote:Where do I go to get the update? Thanks!Angela
Then run the downloaded file. No need to uninstall old version, the update installs over ithe old with no problems.
Cheers
Craig
Just a suggestion for craft edge - it would be helpful to users put a note on the download page stating somethign along the lines of the above - ie no need to uninstall the old....
I am new to scal and this forum but I just got scal 2 on December 22,2009 and I keep seeing that there is an update. Is this one that I should do since I just got it and if so how do you do it. Please help.
