Bulldog
Bulldog
I haven't cut this so let me know if you do!!
- drawing-1.svg
- (41.4 KiB) Downloaded 641 times
Re: Bulldog
don't know how come but I was able to ungroup then break apart and move red x off to side select and delete it then select again on the dog and combine and it worked for me.
Grammy
Grammy
Re: Bulldog
The only thing I can see is the Red x... I will try again.
Re: Bulldog
that's what I did.GrammyKrausse wrote:don't know how come but I was able to ungroup then break apart and move red x off to side select and delete it then select again on the dog and combine and it worked for me.
Grammy
I didn't cut it, but did take a look at it. The file needs a bit of tweaking to make it user friendly. The nodes should be reduced as well as delete some of the unnecessary cut lines/nodes.
