Help Plz!!! Want to cut Dingbat drawn with double lines.
kgsilva
Post by kgsilva »
I'm wanting to cut a dingbat image that has double lines on it. To get it into Inkscape, the only way I know is to type it in as a 'text' object. I save it as .svg and try to import it into SCAL and it doesn't show up. How do you clean up dingbats?
I'm really new at this, so even the most basic suggestions would be greatly appreciated! TIA, Karen
jancy
Re: Help Plz!!! Want to cut Dingbat drawn with double lines.
Post by jancy »
can you post a link to the dingbat & which one you want? how complicated is the design & how soon do you need it?
if it's simple, i can do it now. I can't help with a complicated design right now.
AnointedHands
Post by AnointedHands »
After you type in INK, you will have to select it and then Path>Object to Path
If you don't do this, it will show an empty box when opened in SCAL.
kgsilva
Post by kgsilva »
AnointedHands wrote:After you type in INK, you will have to select it and then Path>Object to Path
OK, thanks for this.... let me go try it. I didn't do that....
The very best tutorial on dingbats and double lines in my opinion is SusanBlueRobot.
http://susanbluerobot.blogspot.com/2008 ... l-via.html
