Help with freezer T
Posted: Thu Jun 25, 2009 5:55 pm
by della
Hi I am trying to figure out how this would translate into a freezer paper stencil. Can someone please give me some tips. I do want to make it all the colors. I can't seem to get it clean looking in inkscape... I also would like to get rid of the tiny writing.Thanks=)
Re: Help with freezer T
Posted: Fri Jun 26, 2009 2:49 am
by TOASTER
I've made freezer T's but not too good with Inkscape but I'm sure some here will help you.
Posted: Fri Jun 26, 2009 4:58 am
That image is pretty low quality. You will have better luck with a higher quality image. I found one here.
http://www.gijoe-stuff.com/images/joe-logo1.jpg You might be able to find a better one. There are eps files of the logo if you can work with those. If you use the image I linked to, trace once with the default settings for the the white, and a second time with the setting about 0.3 for the blue and red. You will need to break apart the image and delete the things you don't want. I have never made a freezer paper stencil, but I imagine you would want to separate the pieces by color so you have one stencil for each color. HTH
Posted: Fri Jun 26, 2009 11:01 am
by della
Hi I found a better quality wallpaper actually and broke apart then removed some lines and found the font to write- a real american hero here's the scut.=)
I'm not sure how to do a screenshot...
