Help with freezer T
della
Help with freezer T
Post by della »
Hi I am trying to figure out how this would translate into a freezer paper stencil. Can someone please give me some tips. I do want to make it all the colors. I can't seem to get it clean looking in inkscape... I also would like to get rid of the tiny writing.Thanks=)
TOASTER
Re: Help with freezer T
Post by TOASTER »
I've made freezer T's but not too good with Inkscape but I'm sure some here will help you.
Toaster
SCAL 2 , SCAL 3, Windows 10
That image is pretty low quality. You will have better luck with a higher quality image. I found one here. http://www.gijoe-stuff.com/images/joe-logo1.jpg You might be able to find a better one. There are eps files of the logo if you can work with those. If you use the image I linked to, trace once with the default settings for the the white, and a second time with the setting about 0.3 for the blue and red. You will need to break apart the image and delete the things you don't want. I have never made a freezer paper stencil, but I imagine you would want to separate the pieces by color so you have one stencil for each color. HTH
della
Post by della »
Hi I found a better quality wallpaper actually and broke apart then removed some lines and found the font to write- a real american hero here's the scut.=)
I'm not sure how to do a screenshot...
G.I.JOE.scut
(37.46 KiB) Downloaded 143 times
