Import from Inkscape to SCAL does not work right
Team_mom
Post by Team_mom »
I need major help! I created two files in inkscape for my daughter's softball team window decals. When I import them to scal, they are distorted, they do not look as they do when I created them in inkscape! What am I doing wrong???
I have attached a screen shot of what they look like in SCAL and the original svg file. Any help would be greatly appreciated.
TRY AGAIN.svg
(15.74 KiB) Downloaded 94 times
hgsa scut pic.png (10.12 KiB) Viewed 1673 times
Team_mom
Re: Import from Inkscape to SCAL does not work right
Post by Team_mom »
Here's the other one......
ANOTHER TRY.svg
(26.26 KiB) Downloaded 140 times
hillsboro girls softball scut pic.jpg (40.44 KiB) Viewed 1679 times
firstcut
Post by firstcut »
I can look at this and guess that something is grouped. For some unknown reason, SCAL doesn't like groups and protests by strewing them about when they get imported. Click on each item in Inkscape and make sure it says path at the bottom info line. If it says group, choose object>ungroup until it says path. Then save it and try import again. In the future, if you need to "group" things, use "combine" (under path) instead.
lkc
Post by lkc »
Yes, I just opened your file in inkscape and you do need to ungroup the three objects, then you need to select your image and ungroup it...after I did those two ungroups it opened fine in scal...hope that works for you!
Laura :)
Team_mom
Post by Team_mom »
THANK YOU SOOOOOO MUCH!!!!!! I was getting so frusterated with this thing, but now it finally works thanks to you wonderful, helpful people!!!!!
Again, THANK YOU, THANK YOU, THANK YOU!!!!!!
lkc
Post by lkc »
Yaaaayyy! Go, Team!!
Happy Cutting!
Laura :D
