Export or Save as SVG
I would love to be able to take an SCUT file that I made and import it inkscape. Would love to see a feature to export to SVG or save as SVG in SCA. Anyone else?
Re: Export or Save as SVG
If we could save/export as an SVG file, possibly, then, we wouldn't need to open or install a font that was used in a project. Or if we're sharing a file, then that person wouldn't need to also download the font/dingbat that we used. Maybe... I'm not sure.What good would this do?
unless that file/font is traced somehow, the font would still be needed.imsocrafty wrote:If we could save/export as an SVG file, possibly, then, we wouldn't need to open or install a font that was used in a project. Or if we're sharing a file, then that person wouldn't need to also download the font/dingbat that we used. Maybe... I'm not sure.What good would this do?I'm an Inkscape idiot (I freely admit it!), so it makes it a little more complicated to share files that I've made.
I don't think exporting svg files is needed, but to be able to trace & manipulate the image would be a great feature in SCAL.
I don't understand why exporting an svg would be necessary.
this is not exactly a piece of cake for any software developer - the ability to save as .svg refers to vector graphic programs and not all of them have that possibility.
Take a screen shot of your SCUT file, and save as .jpeg, import it to Inkscape fill with solid colour and use the trace bitmap function ( Path>trace bitmap) then save the outline as .svg.
Susibi
Susibi
Susibi,
Warning! Dummy Inkscape question coming.............
How do you "fill with color" in Inkscape?
Shari
Shari
To fill a shape with color in Inkscape, just select the shape (should use the first icon so you will have arrows, not nodes) and then click on the color you want from the colors in the bottom of the screen.
If you want to use gradients, you have to go to the Properties box and choose gradient.
