Cutting thru design
wynnepam
Cutting thru design
Post by wynnepam »
I have a cricut expression and for some reason, it is wanting to cut lines thru my design. I have had this problem before and cant remember how it was fixed. Sometimes it will cut letters in to. Any suggestions.
ScrappyDew
Re: Cutting thru design
Post by ScrappyDew »
Is your program in trial mode? Does this happen when you use a cartridge (could be blade drag)?
wynnepam
Post by wynnepam »
Its not in trial mode. I use the same cartridge all the time.
ScrappyDew
When asking about the cartridge. If you are getting stray cut lines when cutting from your machine itself using cartridge ONLY then we can rule out it being a SCAL program rather a machine problem.
wynnepam
Post by wynnepam »
I am only using the cartridge because I have to with the machine. I am cutting my own designs. I ususally have to cut it 2-3 times to get a good one I can use.
