USCutter MH blade setting?
phingersjr
Post by phingersjr »
I'm new to this. I'm trying to figure out the blade settings on my USCutter to cut all the way through the vinyl instead of just a bit. I want to be able to weed around the words I'm printing so it's just the words on the clear top. Then I will heatpress the words to fabric. Make sense? Someone please help me on blade settings!!!
Thank you! :roll:
busterbay
Re: USCutter MH blade setting?
Post by busterbay »
Either increase your pressure or adjust the blade depth. I would try pressure first.
tennalk
Post by tennalk »
On my US Cutter I have to take the blade holder out and screw it up or down to adjust how deep the blade cuts. Then run a test on the machine and see if it is at the correct depth. You should barely see the blade when it is the correct depth.
