My machine is not cutting what the computer monitor is showing. All I am trying to cut is Mom's Sippy Cup in 2PeasMisterGiggles. It cut fine last week but now the lettering does not even look close to the same as the font should be. I have restarted my machine, redid the lettering, rebooted my computer, etc. My machine also has a new blade... Any ideas? Between this and a guy hitting my parked van Monday morining I am going crazy.......
Thanks In Advance
Not Cutting Correctly
Re: Not Cutting Correctly
Try a different new blade. Sometimes the blade isn't centered correctly and cuts are off. HTH
I changed the blade after this started, so it is doing the same thing with the two blades. Just tried it again and now the program is freezing up during the cutting... I have a feeling it has something to do with SCAL.... Any more ideas? I really need to get these cut today.........
They will need a little more info to be able to help you further, see this post
http://forums.surecutsalot.com/viewtopi ... 61&t=13710
Scrappin My Way Through
You could try the Cricut reset procedure. See this post by Inkyfingers for the reset procedure. http://forums.surecutsalot.com/viewtopi ... set#p68580
