Shoes
wreed06
Shoes
Post by wreed06 »
Sandals, Hiking boots, Tennis shoe
tennis_shoe_jarno_vasama_01.svg
(14.89 KiB) Downloaded 414 times
hiking_boot_jarno_vasama_01.svg
(16.1 KiB) Downloaded 358 times
feet_in_sandals_jonadab__01.svg
(14.81 KiB) Downloaded 329 times
wreed06
Re: Shoes
Post by wreed06 »
Tennis shoes, Thongs
thongs_01.svg
(8.92 KiB) Downloaded 345 times
tennis_shoes_jarno_vasam_01.svg
(28.46 KiB) Downloaded 275 times
wreed06
Re: Shoes
Post by wreed06 »
Feet in Sandels
wreed06
Re: Shoes
Post by wreed06 »
Tennis Shoes - Here is an SVG file of the Tennis Shoes with separated pieces, and here is an SCAL file of that SVG file imported to SCAL. I haven't tried cutting it myself, but hope it will work. I *think* you can stretch the file in SCAL. You may need to experiment. The green pieces in the SVG file are mostly shadows, you may not find a need for them. Use the original file as a guide to piece the puzzle back together! If you want the shadow look under the shoes, I suggest either cutting (even hand cut, dare I say!) a disc from blue or green velum, or use chalks or markers to draw a shadow.
Just tried cutting the shoes. All seems to be ok, except for the laces - they are just lines. Guess those will have to be hand drawn with a thick pen or marker, or maybe use a ribbon or fiber?
Tennis_Shoes.scut
(22.48 KiB) Downloaded 234 times
tennis_shoes_jarno_vasam_01_separated.svg
(28.01 KiB) Downloaded 297 times
wreed06
Re: Shoes
Post by wreed06 »
Thongs
Note: Shadows on edges are stroke lines - need to draw them by hand after assembly.
thongs_01.svg
(8.92 KiB) Downloaded 288 times
