Setup Sure Cuts a Lot to use with Singer Momento
craftedge
Site Admin
Post by craftedge »
Sure Cuts a Lot 6 can be used with the Singer Moments cutter. Open the Manage cutters window from the Cutter menu and you can add Singer -> Momento. If you do not see that option, you will need to update the software
https://www.craftedge.com/updates
Sure Cuts a Lot can connect to the Singer Momento via USB and WiFi.
For WiFi connection if the Singer Momento is connected to your home network/router
https://www.craftedge.com/tutorials/sin ... o_wifi.php
If you want to connect wireless direct
https://www.craftedge.com/tutorials/sin ... direct.php
