Can anyone tell me of how to set up Scal so that when you import a file made in inkscape, it imports at the same size. Not even sure if this can be done but I am sure I seen it somewhere.
Thanks for any advice
inkscape to scal
Re: inkscape to scal
If you look up at the dimensions of your project in Inkscape there is a lock you can click on up on the tool bar.. The normally works for myself..
Thanks for your help JO-Anne cutting at the mo but will tey this the next time.
Thanks for sharing.
Helen
Helen
There is a setting in the SCAL2 Preferences for this (Edit/Preferences/General). There is a drop-down box at the top, click on it and select Inkscape. It is worth looking through all of the Preferences tabs to see what options are available.
Thanks Heather will give this a try. Just checked preferences in scal and the drop down box I think you are talking about says 90 (inks cape) and the alpha fill was at 70% I have changed this to 100%. away to draw a simple box in inkscape to see if this helps.
Thanks for sharing.
Helen
Helen
Just tried both suggestion neither are working, thanks for the help anyway.
Thanks for sharing.
Helen
Helen
