Live,laugh, love wall hanging
lindamac
Post by lindamac »
Here is the file for the wall hanging I posted today under DESIGNS. I cut out two files of the base and glued them together for strength. The cream layer was cut out of embossed card stock. I used the same colors for the base and top layer holdling the alphabet. Before removing the alphabet from the mat, I stamped it and embossed with chocolate embossing powder. I also stamped a swirly bird design to hang from the bottom of the hanging. Instead of chain, you could use ribbon. Instead of the stamped bird, you could hang a charm. I inked the cream flowers with brown ink to add some depth. I also went around every thing with brown ink using my home made ink dauber so it would have a vintage look.
Hmmmm, it says my file is too big. How do I make a scut file smaller?
lindamac
Re: Live,laugh, love wall hanging
Post by lindamac »
Here is an svg of the file instead of a scut2 file. You can readjust the files to make them layered and make your own letters. Sorry!
Live laugh love template.svg
(11.03 KiB) Downloaded 326 times
Live laugh love base.svg
(10.59 KiB) Downloaded 262 times
lindamac
Post by lindamac »
I figured out how to zip up the file. You can use a free unzip program called PeaZip if you don't have anything to open it with. Thanks Todd for the suggestion!
Layer alphabet.zip
(77.55 KiB) Downloaded 242 times
Layer 1b.zip
(87.4 KiB) Downloaded 191 times
Layer 1a.zip
(86.05 KiB) Downloaded 165 times
lindamac
Post by lindamac »
Here is part 2
Layer2b.zip
(80.35 KiB) Downloaded 205 times
Layer2a.zip
(79.57 KiB) Downloaded 166 times
