How would you cut this?
I just found out that my Great Niece is into Sponge Bob. I found this in Vector format. What is the best way to cut this? I know how to reduce the colors and break it apart. What I am wondering is do I cut like one big Black piece and then cut the colored sections separately and glue them on top of the Black Piece?
Re: How would you cut this?
That's how the Disney cricut cartridges do it, so I would suggest that as a strategy. It works pretty well. Although, the top part of Sponge Bob doesn't look like it has any lining around it, so it might fit pretty snuggly.
When I cut my Spongebob I cut a black outline background first. then all the pieces which I pulled apart to different places on the mat. Some don't cut very well - like the colours on his legs. then I just attached them all together.
You can see him on my blog if you want to have a look. http://raewyndave.blogspot.com
Thanks.
Most of him cuts really easily as most are big pieces and simple shapes like the dots all over him so you should be ok. Except as I said for the legs and also around his blet. it depends on the size you want to make him of course - as is the case with everything you cut.
Let me know if you strike any problems with him.
Raewyn
Raewyn
