Help ASAP-How to turn off computer security software
Hi i am trying to download my CD WHICH IS #2 BUT every time i try it say i am not connected to the entrtnet or my firewall is blocking it.Well if i remove my security i can redo it.Does anyone know of a way? Thanks
Re: Help ASAP
You wouldn't want to remove your security but you can disable it temporarily....then once you have whatever it is you're trying to install then just restart the program or restart your computer and it should automatically restart.......does that make sense???
Re: Help ASAP
So you want to turn off your security?
To do that you can usually just click on the icon for it and it will have a box that states it is enabled and you can uncheck that for a few minutes, and then go back and put the check mark back to turn it back on.
Or, you can go to Start and Control Panel and Security settings, and it should have a drop down box that says it is on, and click it to change it to off, and then go back and turn it on.
OR, go to Control Panel and Program files and find it and uninstall it...and then reinstall it after.
Usually security programs have HELP menus, where you can search and ask the question of how to turn it off temporarily.
You could even just search the question in google or some other search and then read what other people say as to how to turn of your particular type of security software.
Security programs usually have a page where you can add the names of installed programs to 'allow', also.
You have to inquire of your security company, as to how to add them there, if you wanted to.
Re: Help ASAP
I have done all of that & still wont let me .I still get the same massage
Re: Help ASAP
May I ask what you're trying to install????
Re: Help ASAP
Penny I believe it is SCAL 2 she is trying to installPenny Duncan wrote:May I ask what you're trying to install????
Re: Help ASAP-How to turn off computer security software
Ahhhhhhhhhhhhhhhhh....gotcha.......I read her post wrong then...I thought she was installing CD#2 which I didn't know what that was....I apologize......Well one last thought...have you tried to right click on the .exe file and select Install as Administrator?????
