More cuts!
talanhart
More cuts!
Post by talanhart »
Last Spring, I made 100 of these and now I have an order for 100 more. The last time I made these I cut them apart and weeded each one separately and then I put the contact paper on them. This time I am weeding them in sheets of 8. I put the contact paper on in whole large piece and then cut them apart. It is a lot easier to do it this way and saves a lot of time.
tmarie
Re: More cuts!
Post by tmarie »
wow you have been a busy boy!!,,
I too have been doing alot of vinyl cutting and weeding,,and I have a question for you are any one who plays alot with the vinyl,,sometimes the vinyl stick were it shouldnt like to itself,,,,,lol,, and it leaves a sticky mess,,I hope I'm not the only one who has this problem..lol
was wondering what do you use to clean it off with?
Thanks so much
talanhart
Re: More cuts!
Post by talanhart »
Do you mean glue residue? I use Oracal and every once in awhile, I will have a piece of vinyl stick where it's not supposed to. I carefully pull it off and it when I do, it doesn't leave any residue. Also, try to pull the unwanted piece towards the cut and not away. That way you can push on the vinyl with your finger so it doesn't stretch out of shape.
Goo Gone is good for removing left over glue.
tmarie
Re: More cuts!
Post by tmarie »
oh ok,,I will have to get some of that,,I used WD40 last nite and it worked ,but just wondering what everyone was using
thanks again!!
