Mr. Peanut
Mr. Peanut
Does anyone know where I can find a svg to cut out the planter's peanut guy, you know "Mr. Peanut". I want to cut it wth my cricut.
You can't climb a rope that is only attached to your belt.
Re: Mr. Peanut
There is an EPS file here. http://www.brandsoftheworld.com/countri ... 05971.html
Unless you have a program that will open EPS, you will need to convert it to open it in Inkscape. One option is to use this online converter to convert the eps to pdf. http://convert.neevia.com/
This option will require the PDF to be opened in Inkscape and ungrouped/cleaned up for cutting.
