Re: Sure Cuts A Lot 2.0 For Windows
Longsincove
Post by Longsincove »
Why is it only printing 1/2 of my project on a 12X24 matt?
It stops cutting exactly on the 12inch mark on my 12X24.
Am I doing something wrong OR is it a bug that is being worked out?
Crafty Couple
Gene & Dawn Long
Shelley
Post by Shelley »
make sure you go to "cutter" and then "mat size"...
I have noticed that even if the screen shows the mat you want, it doesn't always cut that way.
Another thing to get in the habbit of is to preview your cut first before cutting it. That'll show right there, exactly how it will cut. I hope this is one of the "bugs" they are working on fixing...
from The Wizard of Oz
lynne
Post by lynne »
Mine was doing this but since installing v2.1 the problem seems to have been ironed out.
Lynne
chasar
Post by chasar »
anyone having an issue with the speed setting? I set it up in my preferences to cut at a low speed but it ends up cutting quite fast. (i set the cricut to low too). Is there a default speed on scal that can't be changed?
