Cutting a shadow?
glitzymitzy
Cutting a shadow?
Post by glitzymitzy »
So, I know how to do shadows on the cricut, but it seems like SCAL won't let me do that? How do I just get the outline of my image to print on SCAL? Thanks.
Re: Cutting a shadow?
You can do that with the properties box. Select your elements that you want shadowed, then in the properties window select shadow or shadow blackout. You can also set how large the shadow is by changing the number next to the drop-down box.
If you added your elements separately you will need to do each separately. If they are all in the same bounding box you can select the whole thing and change it at the same time. HTH
glitzymitzy
Thank you so much...I knew it had to be there somewhere.... Thanks:)
sweet ting
Post by sweet ting »
thanks for the info!
