Cutting multiples of an image
Varsity
Post by Varsity »
Simple question - how do you cut multiples of an image?
What is the best tutorial for cutting especially an image that is multiple colors?
thank you for your time
Re: Cutting multiples of an image
You didn't mention which version of SCAL you're using so I'll assume it's SCAL5.
In the regular version of SCAL, you would select your shape and either go to Object>Duplicate or use the shortcut Ctrl+D. Then you can create rows and columns.
In the pro version of SCAL, you can do it the same way or, in the Cut Settings window, click on the Extras tab and set up the rows and columns there.
With regard to cutting by color, again it depends on which version of SCAL (regular vs Pro). In regular SCAL, you can hide the layers of the colors you don't want to cut on the Layers Panel. In the Pro version, you can do the same or, in the Cut Settings window, click on the Cut by Color tab.
There are free but detailed SCAL4 and SCAL5 user manuals at this link:
https://www.iloveknk.com/support/sure-c ... l-support/
Varsity
Post by Varsity »
Thanks Sandy. This was very helpful. Appreciate your time.
BTW we are using SCAL Pro 5.
Allan
Great! That means you have options. :)
