Which version(s) can be used with the Cricut?
createdog
Post by createdog »
I have the older Cricut machine? Which version can I use?
I'm also considering upgrading to a Cricut Explore. Does this software work with that?
craftedge
Site Admin
Re: Which version(s) can be used with the Cricut?
Post by craftedge »
If you are using the Cricut Explore models you will be able to do this with version 4 of Sure Cuts A Lot
https://www.craftedge.com/tutorials/des ... nspace.php
Version 2 of Sure Cuts A Lot was the last version we created to cut directly with the older Cricut models (Personal, Expression, Create, Cake).
Sales of version 2 ended in 2011, but if you had purchased that version back then, you can use the latest version 4 of Sure Cuts A Lot to create your design and then send it to version 2 for cutting as shown here
https://www.craftedge.com/tutorials/sen ... oscal2.php
createdog
Post by createdog »
Thanks for the information.
I also noticed there was another post on getting SCAL4 to work with the older Cricut models using a separate plugin here
viewtopic.php?f=6&t=42102
I tried it out and this worked!
I will be able to get a little extra life out of my old Cricut and then probably upgrade to their newer Explore.
GlebIN
Which versions can be used with the Cricut
Post by GlebIN »
Hello all Juniper experts,
Which Juniper AP model is similar hardware & performance level with Cisco AP 1600 ?
Which OS the Juniper AP would run on ?
Junos or screenOS ?
Thanks very much
Regards,
Roc
This forum is for users of Sure Cuts A Lot Software. You need to find a different forum to in order to reach owners/experts in the Juniper. Good luck!
AdelaHiddleston
Post by AdelaHiddleston »
You can build your design with the latest version 4 of Sure Cuts A Lot and then send it to version 2 for cutting, as illustrated here.
Last edited by AdelaHiddleston on Tue Nov 16, 2021 8:29 pm, edited 1 time in total.
Anna33
Post by Anna33 »
What is a Juniper? Link?
