I need HELP!!!! Convert Files to SVG
toyabrown
Location: SCAL 1, SCAL 2, Cricut Expressions, Cricut Imagine
Post by toyabrown »
I have looked at every tutorial that is on the forum. I just don't know what I am doing wrong. I have Adobe Photoshop 7 and I can't seem to get the files to properly convert. Can someone please, please help me.!!!!! I am wanting to take some images that I have and convert them to svg.
Toya
Wife of 1 (William 13yrs)
Mom of 3 (BJ, Arreyona, A'Maya)
Follow my blog.. http://creativenspirations.blogspot.com/
Re: I need HELP!!!! Convert Files to SVG
Tell us step by step what you have tried. Also describe what you are trying to convert.
firstcut
Post by firstcut »
If you've read all the tutorials then you know that you can't just convert photoshop files to svg, you have to autotrace them. As Heather said, we need a little more info on what the files are like before we can help you figure out the best way to produce svgs. Are they b&w line art, solid shapes, photos, color graphics, etc? What are the symptoms when they don't convert properly? Or just post a sample image and we'll try to point you in the right direction.
Silvertip
Location: Southern California, SCAL 1/2 Inkscape, Illustrator
Post by Silvertip »
I am very new to all of this but if you post the files I will try to convert or you can send them in a private message to make sure I get them. Also the people here are so great with helping if you ask they will usually do it. Inkscape is a great program but it can be very overwhelming.
toyabrown
Post by toyabrown »
Most of the things that I am trying to convert are black and white. When I do get the file into Inkscape and do path<tracebitmap the whole thing comes up black. The edges aren't smooth. I when I do cut it with my expressions it has more than one line.
Toya
firstcut
Post by firstcut »
Before you trace you need to work with the preference settings until update gives you a good representation. After you trace, view the image in outline View>display mode>outline. There you'll see what potential cut lines will look like. If it is not smooth enough, try path>simplify. Because it is tracing both sides of the line you will get double lines and you will need to path>break apart and delete one set of the lines.
Depending on the image you might have more luck with the paint bucket technique:
http://cleversomeday.wordpress.com/2009 ... -inkscape/
toyabrown
Post by toyabrown »
thanks for all your help. I have got it now....I am on my way....Thanks a million!!!!
Toya
Candie5601
Re: I need some help.... Have jpg
Post by Candie5601 »
I have a jpg picture of a deer head. I can get it converted in Inkscape okay and saved as a SVG.
When I import it in SCAL and cut it... there are alot of little pieces. I want this to be more connected. How do I do it?
Here is the file I want converted and made more connected.
Can someone help, tell me what I need to do!
That image has enough little lines that I used the bezier tool to make the svg. See this post for the file. http://forums.surecutsalot.com/viewtopi ... =20&t=4297
Candie5601
Thanks for converting this file.
So, if I have other clipart that has alot of line and keeps coming up missing lines, I should use the bezier tool? What does it look like.
I need to watch more of those tutorials, but then I get confused.
Thanks a million!
