Cutter cuts image several times
Posted: Mon Nov 09, 2015 3:04 pm
by jdh8
when I import or trace an image into scal the image has 4 or 5 layers on top of each other. you can't see them on the screen but if I choose break apart . I can delete them one at a time. I am importing them from photo shop elements. How can I get all these layers to merge. So the cutter will not cut the image 4 or 5 times. What is the best type of file to save art work in.
Re: Cutter cuts image several times
Posted: Mon Nov 09, 2015 10:37 pm
by craftedge
Check the Layers window to make sure there are not multiple layers of the same shape which would result in multiple cuts.
This can happen if you are doing a Trace with the Color mode set and have too many colors set where it will try to trace slight shade variations of certain colors which may look like a single shape on the screen, but actually adds extra layers for each color.
If this is the case, change the mode to Monochrome.
