Problem inkscape and scal
iris.germany
Post by iris.germany »
I have done a picture with inkscape and have imported after scal.
only now they are tilt on the left quite differently in scal what I have made wrong
I hope you understand what I mean
how can help me?
greetings from germany
iris
AnointedHands
Re: Problem inkscape and scal
Post by AnointedHands »
If you post your svg file, I can look at it. Right, now, I don't understand the problem...don't know what tilts are.
Althea
iris.germany
hi althea
when you look on the first picture
the corner is not as well as on the right like
please tell me as i can share the svg file?
i don´t know, i have never done
thanks for helping me
greetings
iris
When you select preview, are the red lines where you want them? Sometimes svg files don't look right in SCAL, but they cut OK.
If you look beneath the area where you type, there is a section that is labeled filename, with a button that says "Choose file". Click on that to add files to your posts.
AnointedHands
When you click on Reply, scroll down to Filename and click on browse, select the file to import, click on open and the file will be added. then click on Add the file and it will be in your message, click on Submit.
HTH
Althea
