Cutting mats
Cutting mats
I tried to look for the answer before I posted this. But it says that the words are too common. Anyway here is my question. Is there a way to make your own mat or do something about the sticky on the mats? I spent hours drawing and then when I went to cut my paper slid all over the place. I have tried a tip I saw here a while back and cleaned the mats I have with baby wipes, but...
Re: Cutting mats
There are lots of posts, I think it might be time for a section on helps....
but to answer your question, yes you can help your mats. I personally like the two way Zip pens. I get the wide tip one at Joanns for a few dollars, run it all over the mat, let it dry a few minutes and then I'm off and cutting again.
Re: Cutting mats
Here is one of the posts. http://forums.surecutsalot.com/viewtopic.php?f=6&t=3031
Re: Cutting mats
HeatherM - Thanks so much for the link. I read the first 2 posts in that thread when it was original. I guess sort of why I was looking for it but couldn't find it! So glad there are experts who can help.
Re: Cutting mats
i use quilt basting spray its a repositional spray work great u can get it at walmart for around 4 dollars a can and it will last along time
Re: Cutting mats
Something that I do is using painters tape (it is the blue kind that looks like masking tape that you put up when you paint) to tape down my paper when the mats are no longer sticky.
Re: Cutting mats
I happen to have zig glue and tried that. I have this old old old mat that hasn't worked for at least a year and now viola super duper sticky!
Re: Cutting mats
Vellum spray also works, I painters tape the edges and then spray the mat. Works great
Christina
“I do that which I cannot do in order that I may learn how to do it.” ~Picasso
Re: Cutting mats
I use a mixture of Craft Smart's Off n On Glue & Water and coat my mat with a brush, it works fabulously
I did try one of the repositionable sprays and found that it was just completely over sticky and tore everything I put on it
All trial and error I suppose and seeing what works best for your own particular usage of the mats .... happy trialling
Cheers Kris
Re: Cutting mats
I love Krylon repositional spray and love it more than my original mats. (I have only found this at Michaels). I tape off the edges with masking tape, and I spray 2 or 3 light coats ONLY. Then you are good to go and better than new!
I also tried Elmer's repositional spray and made my mats way too sticky, like someone else mentioned. The Krylon was a much thinner coat, so it worked well.
