I am trying to cut out the inside of an image.
Can anyone tell me how to do this? I would rather not ask someone to do it for me.
Paula
cut out inside of image
Re: cut out inside of image
Paula Ann, "how to cut out the inside of an image" is a bit vague to get some help.
Can you post the file without CR violation so someone can explain it to you. Or post something similar?
This is the cat.
Heather was kind enough to convert this to an SVG because I was having problems with my software.
I want it to be similar to the dog.
(The white is "empty" space~for lack of a better word")
Paula
Paula
- stick dog.png (220.79 KiB) Viewed 4510 times
- rescue cat.scut3
- (56.35 KiB) Downloaded 225 times
Heather was kind enough to convert to an svg
viewtopic.php?f=6&t=33307
That is the cat file.
My file initially could not be opened so she posted the svg for me.
Paula Anne,
I'd make a shadow layer of the cat at a setting of 2.50 or 3.00 or more depending on how thick you want the stick line.
Select All
path/back minus front
This will take out the interior of the cat leaving the solid stick lines, plus the facial features.
Good Luck, and check back in if this is not what you wanted.,
Select All
I made the shadow layer.
Then I did
Select all/path.....but I don't get the option, back minus front.
So, I am missing doing something, but I don't know what it is
Then I did
Ahhhhh HAAAA! I had to have the nodes showing!
I figured it out. Thank you soooooo much for the help!!!
Yipeeeeee!!!!!
have a great day!
paula
Yipeeeeee!!!!!
have a great day!
paula
When you made the shadow layer did you leave it underneath the cat..
Try again and let me know where it goes wrong again. I've done this 3 times in eCAL with no problem
Thanks Susan...I got it
Optimism is frustrated after the calm, optimism is insipid in confidence, optimism is setback after the surrender, optimism is wow sharing a leisurely in poor and difficult. One with optimistic, have the perspective life in the eyes. One with optimistic, have the power. One with optimistic, have the hope of a ferry, who owns optimistic, who had difficult of dare to struggle spirit, as long as alive has the power to build brilliant tomorrow.
