thescrapgirl wrote:Thanks ladies...
I did figure it out and now my little machine works... but to clarify, if I get the Expression 2, my SCAL wont work at all with it?
So all the piecings files that I have accumulated over the years just go to waste?
Why?.... ugh....
Thanks!
Why? because provocraft want you to use the machines as they intended, and buy carts, that's is how they make money and what you agreed to when you brought a cartridge based machine, you will buy the carts and use the files others say you should.
if you buy a different machine (NOT CRICUT and NOT cartridge based) then your files can be used with that, scal 3 will open them and work with the rest of the cutters out there (at present)
none of the current cricut machine work with scal, remember the big court case? that stopped you using 3rd party (I.E.scal) software with the machine because provocraft were bringing out their own software, BUT you still have to buy the carts or files to use it. so buying the expression won't work either as NONE of the cricut machines, unless they are 2nd hand and not updated firmware to current, will work
Gaz
Computer:IMac running Mojave
