Does anyone know if this can be done. I have found some designs I want to purchase but they are only available in those formats. After many hours of trying my hand at inkscape I am still inkscape illiterate. Any words of wisdon from anyone. Thanks in advance for any help or advise
Kathy
http://calowaycreations.blogspot.com/
How to convert AI or EPS to SVG
Re: How to convert AI or EPS to SVG
I *think* you can import AI files into inkscape, I couldn't see where it works for EPS files... but someone more experienced with inkscape can probably give you a better answer.
If inkscape can't, a program called CorelDraw can import both file types, and then export them as SVGs (but it isn't a free program)...
http://www.cougarrx.com
All my files are for non-profit use only... use them, share them, give them as gifts, but don't sell them
You should be able to open AI files with Inkscape if they were made with AI version 9 or higher. You can also convert EPS to PDF with this online converter. http://convert.neevia.com/pdfconvert/
I would talk to the person selling the files to make sure that they will work with you if there is a problem first though. HTH
