Need help with SCAL 2.012
I am having trouble with this version 2.012 of SCAL on Windows XP. I cannot import svg's created in iNKSCAPE. I AM able to import the same files to SCAL version 2.011 on Windows 7 on my laptop. I can't find any place where I can redownload 2.011 to my PC with vs. 2.012. Can I go back to 2.011? How or where can I find the download? Thanks.
Re: Need help with SCAL 2.012
I'm wondering if Ink is the problem. What version of Inkscape are you using? (I use 0.46 and can open the svg files I created in Ink without any problems on my Vista and Win 7 laptops using SCAL 2.012) I've heard about a lot of conflicts when using Ink 47 with SCAL 2.012scottie wrote:I am having trouble with this version 2.012 of SCAL on Windows XP. I cannot import svg's created in iNKSCAPE. I AM able to import the same files to SCAL version 2.011 on Windows 7 on my laptop. I can't find any place where I can redownload 2.011 to my PC with vs. 2.012. Can I go back to 2.011? How or where can I find the download? Thanks.
There's a number of posts on the Inkscape forum about 47 being unstable, that's why I downloaded and installed the older Ink 46 version.
I can send you the link to the download for the older Ink 46 version if you want to try using it to see if that fixes the problem.
Hope that helps
Craftedge can send you 2.011 if you email them at support@craftedge.com
Also, they may know how to fix this without having to roll back to a earlier version of either SCAL or Ink.
I had a problem with an Ink47 file and SCAL 2.012 a couple of days ago with my Win7 machine. I had to use the old workaround of copying my work into a new file, then it worked.
