I am the Crafts Director for our VBS and the theme is Western. I want to Make badges (stars) with the teachers name welded in the middle. Is this possible? I am still using the SCAL 1 verson.
Thanks so much
Della B
Star Pattern
Re: Star Pattern
Heather M posted a Sheriff Star Badge svg on this forum. Unfortunately, I don't know how to link to it, but if you do a search under Sheriff Star Badge you will find the svg file. You should be able to import the badge svg into SCAL, type the name in the font that you want, and place the name inside of the badge. It should cut out the badge and cut the name out of the inside. You could also cut out some plain star badges (different color) the same size or in shadow to go behind. This would make the name stand out. Hope this helps. Kim
Re: Star Pattern
Thanks so much. That's the pattern, now to get the names. I might do the names separately and glue them to the star.
