URGENT! I filled all the SCAL 12x12 mat. Cuts 6x6???
Posted: Tue Jan 26, 2010 5:44 am
by evamar
Hi all,
I'm sure I'm doing something wrong, but cannot see what!
OK, I need to cut A LOT of butterflies, all the same design. So, I copied and pasted in SCAL, grouped them, and they nicely fit all the 12x12 mat.
Then I try to cut it. I put a 12x12 card (not really, just an A4 and a piece to fill the space) and it does recognize it as 12x12.
OK, I press CUT, and it starts cutting but only about 6X6, so most of the card is wasted and only 2 are properly cut. It actually cuts all the butterflies half way to make a 6x6 mat.
I basically need to cut the same design lots of times. What am I doing wrong? I'm wasting a lot of card, and getting only 2 butterflies is silly!
Can anybody help, please? I need to get this going quite urgently, have quite a lot to do and also cards and little boxes
PLEASE?
Re: URGENT! I filled all the SCAL 12x12 mat. Cuts 6x6???
Posted: Tue Jan 26, 2010 5:51 am
by Sweetness4713
Did you go to the toolbar when you open SCAL and check off the mat size 12x12 under cutter...Sounds like you didn't check it off.....
Posted: Tue Jan 26, 2010 6:16 am
by evamar
Hi, yes, it's definitely 12x12, I can see the butterflies filling up a 12x12 mat, and just to make sure I checked it again.
Gonna try again just in case, but if I see a 12x12 matt where I put all the butterflies, then it should be a 12x12, isn't it?
OK, now it's working... third time lucky, as they say!
SCAL seems to be a bit temperamental, but still great.
Thanks a lot, Jo-Anneb, it's working now!
:D
