Cropping in SCAL
kgator
Cropping in SCAL
Post by kgator »
Does anyone know if you can crop an image in SCAL? Or maybe even just erase parts of it that you don't want?
Re: Cropping in SCAL
I just lay a square over what I don't want and go Path Back minus Front. Then if I have to go a tad more I use the nodes tool.
Or, you can just use the nodes tool and drag a box around what you don't want and the nodes turn blue and hit the delete key on your keyboard.
I do the same thing as gj1.. easy peazy..I just wished they would have supplied us with the eraser tool..LOL
kgator
Post by kgator »
Thanks! You guys are lifesavers! And so knowledgeable!
Another question you might know the answer to... is there anyway to get images from Cricut cartridges into SCAL?
Very very impossible..
There is no reason to do that because there are so many wonderful .svg and .scut files to choose from.
alliellis
Post by alliellis »
Thanks for the tip about adapting designs using the node tool, and path menu. I have just tried it. I think it will make life easier. Thanks again you are awesome
Allison
http://www.craftoutloud.co.uk
craftsbyalli.blogspot.com
It does make it easier in Scal. Glad the pointer was helpful.
rebecky
Post by rebecky »
I have a hard time getting my nodes to move/delete. Is there a special way to do this?
May the Lord keep you and watch over you.
Ungroup and Break Apart first. Put a box around the image each time...then the nodes should select easier individually and turn blue before you hit delete on the keyboard or grab and try to move the square node, and the round ones change the arch of the section.
