Change line color in SCAL?
I am new to SCAL and I am enjoying the creativity of this very flexible program on my mac. Is there a way to change the color of the cut line in the objects that have been created? I really just want to change all the cut lines to a single color so that I may visualize where they are on the page. I understand that I can preview and see the cut lines in red with the rest of the colors blanked out, I am looking for a way to view the many different cut line colors in one uniform color. Thank you.
Re: Change line color in SCAL?
Hope I guide you in the right direction. My SCAL skills aren't that great. Select your design or shape. In the "appearance box" click on the little colored square next to "fill" and "color". That will bring up a color palette and you can customize and choose your colors there. After you choose one, click "OK." Hope this helps.
Adding to the previous post which is right on you may also have to uncheck View/show outline only to see the color fill.
If you only want all the lines the same color most likely those lines are on different layers. Next to each layer is a color for the stroke outline. You change that just like the change fill color.
See this post for more.
http://forums.surecutsalot.com/viewtopi ... =6&t=19426
