Has anyone cut fun foam? I saw a card made with some fun foam... and I thought huh? I wonder... so here I am posting to find out... Can I? Can I?
Meggers
Cutting Fun Foam...
Re: Cutting Fun Foam...
Yes you can but you need a very very sticky mat.. Also you need to remove the rollers off to the side on your cricut or it leaves a dent in the foam.. and tape the edges of the foam down..
Here are 3 different methods. I usually stick to the the really thin kind from the dollar store and get decent results.
Glide spray method
http://kandrewdesigns.blogspot.com/2010 ... puffy.html
Sanding block method
http://joyslife.com/how-to-cut-foam-in- ... nt-magnet/
Release point method
http://www.creativecutter.org/2011/01/c ... ricut.html
Glide spray method
- Location: Dartford Kent UK Using a MAC with OS Snow Leopard 10.6.7 SCAl 2.012
I just cut some the other day trying to make a golf green, I passed it through twice, DON't UNLOAD it between cuts
even then you may need to snip with scissors . I also put my blade on 6 but kept the pressure at 3 .
maybe a third pass would cut it cleanly through,
try on a spare piece if you have some.
My rule is always cut from scrap paper or scraps if you have it of whatever I am using so you get the settings right.
Hope this helps
OH How do you get the rollers out of the way?
best wishes
Scatty
Hope this helps
best wishes
Scatty
Use a MAC computer running 10.6.7: SCAL v 2.043
If you see someone without a smile give them one of yours!
I have joined the wonderful world of Fiskateers no 7771
