I would love it if someone could create an SVG file that is similer to this :
http://www.iheart2stamp.com/wordpress/w ... edrose.jpg
I have found one or two on the web but they do not cut properly and I end up with a straight line across the rose making it totally unusable. So, if any kind hearted soul would create this for me I would be SO happy! Thanks!!
3D Spiral Rose
- Location: Dartmouth, Nova Scotia Canada Using Scal2, Inkscape .47, Vista
Re: 3D Spiral Rose
Thanks for posting the file but that is the same file that doesn't work for me. I did purchase the full version of SCAL2 last year so that isn't the problem. Hoping someone out there can help.
Re: 3D Spiral Rose
Sorry it doesn't work for you.lk2thestarz wrote:Thanks for posting the file but that is the same file that doesn't work for me. I did purchase the full version of SCAL2 last year so that isn't the problem. Hoping someone out there can help.
Re: 3D Spiral Rose
That file is an open path. You need to make sure that it doesn't touch the cutting boundary, or SCAL will close the path and give you the extra cut to close the ends. The cut preview will show if it will cut correctly or not. HTHlk2thestarz wrote:Thanks for posting the file but that is the same file that doesn't work for me. I did purchase the full version of SCAL2 last year so that isn't the problem. Hoping someone out there can help.
