converting files
converting files
can i convert jpg etc to svg in the SCAL? and if so how do i do that.. if i have found an image and i want to convert it to cut on the cricut .. thanks
Re: converting files
Using a jpeg all you have to do is open up scal and using either the file menu or the trace button(above you virtual mat) select trace image, when the window pops up select browse and find the file on your computer and select it. Better yet here is the link to the tutorial that will help you alot more than I can.
http://svgcuts.com/blog/2010/06/08/sure ... -tutorial/
Good Luck Hope This Helps
Scrappin My Way Through
okay thank you very much.. you guys are fast around here.. and do u do the same with the scut files too.
I pretty sure you can see this thread
http://forums.surecutsalot.com/viewtopi ... =6&t=13766
