when I get something done and want it multiple times on my mat is there a copy and past function?? I don't want to have to type, shape, and then make sure that all words are the same size step by step.. I hope someone understands what I am trying to accomplish.
thanks
Kim
can I copy and paste in SCAL2
Re: can I copy and paste in SCAL2
Yep there is.. just place your image.. then go Edit/copy/and then past auto fill..
OK what am I doing wrong? I made a design and want to copy and paste it all over the mat to cut multiples. When I do a copy and paste they all end up on top of each other all over the page?
What size is your image you are trying to cut??
Before you copy your work, select all (Control A), then Group (Control G). That will keep everything in the same relative position. HTH
once you paste them you do have to arrange them on your mat
If you want the whole page filled, you can copy your image then paste (auto fill) located in the edit menu.
