ok- i actually made a sunshine like i want. used INK - drew a circle - used bezier tool and drew rays. selected all - combined - and two rays combined and the rest did not. WHAT HAPPENED.?
I don't know how to save a pic and put here. the doc extension would not work.
sunshine rays
sunshine rays
- sunmine.svg
- (4.84 KiB) Downloaded 91 times
Theresa
Re: sunshine rays
here's a photo of your sun. unsure what your question is?
People here will help in anyway they can
- Capture.JPG (22.49 KiB) Viewed 2028 times
Re: sunshine rays
I'm not sure what happened in Ink. My solution was to unfill all the artwork, draw a slightly larger circle and add to the shape area and expand.
Re: sunshine rays
thanks Todd. the thing is- i don't even know how it got filled
oh- and how did u post the photo. i did "print scrn" but it wouldn't work?
Theresa
Re: sunshine rays
You used Path/Combine instead of Path/Union. Path/Combine just makes everything into one object, it leaves all of the nodes/cutlines there. Path/Combine can be undone at any point, since nothing is lost/removed.
Path/Union is like welding, only it's permanent since it removes nodes/cutlines and can't be undone after you close the file. HTH
Re: sunshine rays
Heather - that ans. a million and one questions. THANK YOU. i always wondered what the diff. was and also is that why once you do Path/Union and save - then u can't go back and change it since the nodes were removed? hmm cool
Theresa
Re: sunshine rays
Yep. That's why I tend to keep a "parts" version of a file and a "cut" version. The "parts" version doesn't have anything unioned together, the "cut" version has a union done as a final step in preparation for SCAL.TheresaTT wrote: and also is that why once you do Path/Union and save - then u can't go back and change it since the nodes were removed? hmm cool
- Jasen.
Re: sunshine rays
sure do love this question and answer board.
Theresa
