Would like Elk, Bear and Deer files
MommaJamma
Post by MommaJamma »
I am looking for an elk, bear and deer. Instead of a silhouette, I would like for them to mainly be black but have cutouts to show the eyes and muscle tone. The cricut campout cartridge has the images that I would like.
THANKS!!!!!!!!!!!!
lindamac
Re: Would like Elk, Bear and Deer files
Post by lindamac »
If you use the search feature on this forum you can probably find them.
TheresaTT
Post by TheresaTT »
MommaJamma,
If you go to HeatherM's site below, you can find out how to convert the images from the campout cart to svg after downloading the handbooks from the other site listed below. This is great info for people that don't have the carts. I have done it so i know it works. Good luck.
Thanks again HeatherM
http://imagesbyheatherm.wordpress.com/2 ... es-to-svg/
http://www.4shared.com/dir/6762632/862f ... aring.html
Theresa
MommaJamma
Hi Theresa!!
Thanks for the information and links. I followed the instructions from the link, but was unable to paste the images after I had copied them. Do you know what I may be doing wrong??
THANKS!!
Tonia
Are you using a Mac?
MommaJamma
I do not have a mac, I have Windows XP.
THANKS!!
You selected the part you wanted to copy, Control C, then Control V?
MommaJamma
Yes, I selected the object, hit Control C and the Control V. It selected the image and then after I hit the Control C and Control V, it acted like it had pasted the object, it had arrows around the box, but there was no object in the box.
THANKS!!
You either need to set a fill, or change the opacity. To set the fill, with the object selected (or right after pasting) click on one of the colored squares at the bottom of the Inkscape window. If that doesn't make it visible, you need to change either the alpha or the opacity. Dan99 has a good tut on this. http://dan99.blogspot.com/2009/05/video ... ty-in.html
btails
Post by btails »
will get you an elk later this evening..I have other deer so let me know if this doesn't work...Judy
this came from Gary's @ www.signtorch.com
deer_family1=.svg
(18.38 KiB) Downloaded 572 times
