Hi,
So I have scal 2 and for the life of me I can not figure out how to rotate an object. I can see rotate and skew but nothing happens. In the text tools you have a choice to enter degrees etc. What am I missing and how do you rotate an object?
How to use "rotate" in SCAL 2?
Re: How to use "rotate" in SCAL 2?
If you are rotating an object other than text select the Object menu, then Transform, Rotate and type in the degree of rotation.
If it's text you're rotating, the latest version of SCAL (2.004) has a degrees box under the Rotate box in the Text properties box.
Thanks Narelle.
