welding in inkscape
Rebecca McConnell
welding in inkscape
Post by Rebecca McConnell »
I'm trying to weld a border in inkscape. I got it to weld on one end but not the other. Can someone help me? Thanks, Rebecca
card2.svg
(19.4 KiB) Downloaded 179 times
Last edited by Rebecca McConnell on Fri Aug 14, 2009 8:14 am, edited 1 time in total.
Rebecca McConnell
Re: welding in inkscape
Here is the correct svgs. Sorry, Rebecca
ms border punch.svg
(18.26 KiB) Downloaded 171 times
It looks like it will cut fine just like it is. You don't need to, but if you want the dots to show in Inkscape, Break apart your border, select all of the dots, Path/combine (control K). Select the dots and the border, Path/Exclusion. HTH
Rebecca McConnell
Heather,
Not sure I made myself clear--I want the border on both ends of the card. Rebecca
If you are going to weld the border to a card, you will need to do what I posted above, otherwise the dots will disappear when you weld. I think why you cant get it to weld is that you are probably importing one file into the other file, and Ink automatically groups imported vectors, even if there is only one object. After you import the file, select it, and ungroup it. Then you will be able to weld. HTH
Rebecca McConnell
Thanks --again-. Seems you always come to my rescue! Rebecca
