I just found a bug
scrappinvt
I just found a bug
Post by scrappinvt »
I have been using Scal 2 since yesterday. Today was the 1st time I had to cut an object 4.5 x6.5 , what I found was when I previewed it it did not show anything that went over the 6" mark, it was a rectangle going horizontal(portrait). If I turned it to go vertical instead it showed. I did have my mat set at 12x12 as that is what I was using. I hope I am explaining this right. Anyone else run into this or have a solution for me?Thanks
jomatho
Re: I just found a bug
Post by jomatho »
I had the same problem last night - I tried to cut a 12" border and only the left half cut. When I checked back on preview, I noticed only the left half was showing. I had turned my mat so the arrow was viewed on top, but I didn't think of that at the time. I was cutting a design I made in SCAL 1, so I thought maybe that was it and I redesigned it in SCAL 2. It worked on the redesign, no problems in preview or cutting, even with the mat turned to view arrow on top??? Hope that makes sense. I also had problems when rearranging designs on the mat, It would get hung up and want to close. I am using Vista and with Scal 1 I had to go to properties and had to select windows service pack 2 and hit apply. Since I did the same thing with Scal 2, no problems.
J Marie
Julie.Jenkins
Post by Julie.Jenkins »
When I played with it this morning I noticed something similar, I had a 12x12 screen open but when I previewed it showed that only the top 6 inches would cut, I selected 12x12 from the drop down menu again and it fixed it in the preview.
I'm sure where this is so new there will be some bugs for awhile. I only have the trial right now, since I only saw it this morning but hope to upgrade soon, it has everything that I've wanted (besides the bugs :)
Silvertip
Location: Southern California, SCAL 1/2 Inkscape, Illustrator
Post by Silvertip »
From what I have heard from friends, it will only cut the 6x12 mat size even if it shows, the 12x12 mat.
Beanie
Post by Beanie »
Yes that is one of the bugs Todd has been working on this weekend said there should be an update today or tomorrow!
