Jamie,
Glad I could help! This is all so new to so many of us I sometimes feel we are all walking, hand in hand, to the first day of kindergarten!
Now, as to the reason you can't view the files from the library you mentioned: When you download the file either put that file in a pre-existing folder when you can find it later or create a new folder for that file. (I think the file was 'zipped' (compressed) so, if it was, you will have to 'unzip' it first.)
The library you mentioned consists of a main directory followed by many subfolders. You have to click on the subfolders before any of the .svg files are accessible.
So, if you want to open these images within SCAL, you have to:
1.) make sure the file is 'un-zipped'
2.) open SCAL
3.) within SCAL go to "File-Import", navigate to the library's main folder, click on a subfolder, and then click on one of the .svg files
4.) the image will open up and will be very tiny so grab the lower right corner and drag it diagonally down and to the right
Now, doing it as outlined above is a very slow and tedious way to view these files. There is a faster way to view many images at a time by using a nifty .svg file viewer called Renesis Player (which someone else on this list kindly shared with us). I can walk you through using Renesis later, but right now I just want to know that you "can do it" using the 4 steps I outlined above.
Does this help you more? Remember, we are all walking to kindergarten together here!!!
Come back to this thread with your results of the 4 steps I just gave you and then I can walk you through using Renesis.
Shari
(whose "s" key is sticking so pardon any missed "s's" in my message - I think I have a donut crumb stuck under my 's'.......!!!!) (We, or I for sure, NEED a spell checker on this message board!)
