Todd, you rock! Now we can cut chipboard, too!
Imagine the possibilities- cut the chipboard, then cut PP to put over it- what a time saver! I'll never have to use an Xacto knife again!
Thank you Todd! Multicut!!!!
Re: Thank you Todd! Multicut!!!!
Hint: Attach your PP to the chipboard before cutting. One series of multicuts and you are done!kelmarfar76 wrote:Todd, you rock! Now we can cut chipboard, too!
Shari
Bug Safe: http://www.pbase.com/bugsafe/inbox
My Blog - "The Bug Stop" - where you can find my .cut files:
http://thebugstop.blogspot.com/
Thank you so much for the upgrade Todd.
Weld and shadow work perfect and so much easier than DS.
Love it!!!!!!
Love it!!!!!!
Many thanks for the hard work you've put into updating the program Todd.
Susibi
Susibi
You can cut chipboard on your cricut??
Actually, I like the way you just click a work, click weld and DS would scrunch the letters together. You may need to adjust a letter or two, but it was fairly automatic. With SCAL, there is no automatic feature, you have to manual move each letter. I don't necessarily see it easier, but I'm sure happy it's here!Weld and shadow work perfect and so much easier than DS.
Wow this all just keeps getting better!
I read that you can cut chipboard now? Is there a special setting it must be on?
You need "multi-cut" set to at least 2 sometimes more than that. Best bet is to do a couple of test cuts first to judge the sharpness of your blade versus the thickness of the chipboard. If you are wanting to purchase chipboard, the .022 thickness is about the max thickness that can be cut.scrappy_happy_moms wrote:Wow this all just keeps getting better!
You can find "multi-cut" under the "cutter" tab.
Shari
Is anyone having trouble cutting anything thicker than cardstock? I have very thin chipboard and am using the highest pressure and 4x cut and fairly new blade and still won't cut. What could I be doing wrong? Any ideas?
*** I figured it out. The blade needs to be turned to 6 (deeper cut) and then highest pressure and multi-cut
Suzy
